They're 16"
Front 7J, ET35
Rear 8J, ET38
Is this a good wheel offset/stagger for the MR2?
![Think :-k](./images/smilies/eusa_think.gif)
HughesR1 wrote:Thanks for both of your replies, Marf that looks like a good setup!
I have a feeling the 17's my car came on had a similar setup which seemed to work well, although I don't have anything to compare it to![]()
HughesR1 wrote:I can't remember if I read somewhere about 215 40 16(7J) front and 225 45 16
(8J) on the MR2, as to raise the rear up which would in turn, put more weight on the front.
Is this commonly done?
Marf wrote:Which tyre do you have on the rear in a 235?
Kitsan wrote:The only issue you would would have Alex is putting too wide a wheel on the front as the teins are a tight fit, or were at least with my budget rims.
