Where are you? I'd see if there's an MR2 specialist or knowledgeable member nearby who can give it the once over for you.
Really need a lot more detail to access the extent of the problems.
I'm guessing you don't want to spend a fortune, check new part prices with forum traders or classifieds section for 2nd hand.
nsf steering arm
- ![](./images/smilies/spacer.gif)
replace with new or good 2nd hand
nsf wheel binding possible caliper/hose-disc has signs of over heating
-![](./images/smilies/spacer.gif)
probably a caliper(s) binding, check
www.biggred.co.uk ![](./images/smilies/spacer.gif)
www.brakeparts.co.uk/ both do refurbished calipers which will be a lot cheaper than getting a mechanic to sort them.
front and rear backing plates corroded
brake disc dust shields?
rear brake discs poor
New discs needed, best to change pads as well at the same time, I'd recommend genuine OEM Toyota parts, check prices with forum traders
osr abs sensor bracket damaged
check classifieds breaking section should be able to get what you need 2nd hand cheap
oil sump very poor condition
(need to replace)
suspension bushes cracking
need to know which ones?
underside of vehicle rusty
to what extent, is it an MOT fail problem?
radiator leaking
check classifieds for decent second hand one or one of the forum traders/ebay for a new replacement
HT leads poor
Check classifieds breaking section for decent 2nd hand replacements or traders for new
oil leaking into spark plug holes
Probably cam cover seal leaking, get new seal from Toyota, simple fix
timing belt
Any records of if/when it was last replaced, any paperwork with car, can you check with previous owner, any sticker with mileage on the cover?
air filter box insecure
Probably just needs bolting up or check classifieds for replacement if something is broken
cooling fan fault?
What is the fault?
exhaust rusty
Find out the extent of the rust, if it is just surface rust then no problem, if there are cracks then check classifides for a 2nd hand replacement
battery terminals poor
get new terminals, easy fix
