Only problem I could see is installing it so it dose not leak boost under pressure?
![Think :-k](./images/smilies/eusa_think.gif)
http://www.ebay.co.uk/itm/Air-Charge-Te ... 2961wt_932
RedMR² wrote:I personally wouldn't bother.The refresh rate on that is every second.
If I was going to fit one, I'd be going for thermocouple spa gauge, with a refresh rate of 4 times per second.
Difference is, the spa gauge is 300 quid, and totally worth it.
