[Mk2] [Turbo] Oil light on
Sorry if it's been posted before had to replace my dials due to the clown who I brought the 2 off had cut the metal strip that makes the engine light come on and found out my knock sensor is dead any way now the orange oil light comes on what's it mean and how to remove it thanks ?
Re: [Mk2] [Turbo] Oil light on
pagey1982 wrote:Sorry if it's been posted before had to replace my dials due to the clown who I brought the 2 off had cut the metal strip that makes the engine light come on and found out my knock sensor is dead any way now the orange oil light comes on what's it mean and how to remove it thanks ?
Commas, full stops and capital letters all help you to be understood
OK, which orange light comes on?
Why do you want to remove the orange light? - Fix it instead!
What metal strip? One on the dials PCB?
Orange oil light is low oil level.
Sorry was in a rush dont mean removing the bulb ment to get it to go out ?
the turbo dont have low oil light, i thought it was oil pressure if that came on
It's a bit of a pain really it's a uk shell with a turbo engine.they are uk dials fitted.i should have had a look in to the car cuz the bloke seems to have lashed things in
OK, N/As had oil level sensor in sump. Unplug it and light will come on.
Since you have no sensor, light will always be on.
Remove bulb.
Remove bulb.
alanmr2turbo wrote:the turbo dont have low oil light, i thought it was oil pressure if that came on
Thanks that's something new I've learnt today That's blooming stupid! My Supra has an oil level warning just assumed the MR2 would as well..... goes off to double check the oil level!
Removed cheers guys for the help. Once again
