This thought literally just popped into my head but for the past few days i was think about buying a new lump from a turbo mk 2 and i just thought...
Has anyone ever mounted a Supercharger to a 3SGE?
[Mk2] [NA] Mouting a super charger to a 3SGE?
Re: [Mk2] [NA] Mouting a super charger to a 3SGE?
I think it'd probably be way more cost effective to just get a 3S-GTE...
yeah probably...
not even if you only got a small one like off a cooper S 1.6?
so it shouldn't strain the engine to much?
I tried it,
Relocated the alternator,mounted the sc in its place,after having a bracket made up........
TBH i couldnt be bothered to carry on after realising that its way less efficient than a turbo,and for all the hassle and costs involved it just wasnt worth it.
Now if you said twincharger,like the guy in the states with his lotus,
http://www.youtube.com/watch?v=HmscSzFurwg
using an mr2 5 speed box as it was the only one that would hold all the
650 horses
650 horses
Mmm compound turbo setup. I have been drooling over these since I saw this car http://www.youtube.com/watch?v=4iObLBYEkpE in this thread http://www.dsmtuners.com/forums/custom- ... -up-2.html some time ago.
Need to build the engine for mega boost though and working out the turbo sizes requires some serious knowledge (or copy someone else!) Similar thing would work with a super charger aswell to make a super turbo but then intercooling gets harder and you have to drive the super charger all the time even when boost is not required.
Another thread suggests a GT2871r and a GT4294r can be used to make 45psi and 700 whp from a 2.0 4 pot with boost from 2800 to 8000!
Road_Rebel wrote:yeah probably...
The M45 is pretty small for a 2litre engine, they'll struggle to make 200hp. Better off going with an MP62.
How much do power do you think the NA rev 3+ engine could take 'stock' ?
Hard to say. I'm guessing that because the 3SGTE is readily available not many people will have tinkered with forced induction on a stock 3SGE.
What compression ratio is a 3SGE? Do they have piston oil squirters?
for those interested in compound charging this thread may be of interest...also make sure you click on the link posted in this link!!
http://www.vauxhall-sport-forum.com/php ... rging.html
dazzz wrote:I'm no expert but
Marf,
The 3sge doesnt have oil squirters,
and i seem to remember that it has a higher compression ratio than the 3sgte.
The one i was playing with at the time was an m45 eaton.
I'm experimenting with a Toyota SC12 'charger, made the mounts in plastic, need to find someone to make them up in a decent thickness steel for me
Nev wrote:I'm experimenting with a Toyota SC12 'charger, made the mounts in plastic, need to find someone to make them up in a decent thickness steel for me
The SC12 is almost too small for the 4AGE...
An interesting project I'd have thought would be a 3s-gte block married up to a Rotrex SC.
So the GTE block has oil squirters?
Will the GTE block marry up to the GE head and sump without an issue?
but then i guess you need a better oil pump also?
Road_Rebel wrote:So the GTE block has oil squirters?
At this rate it becomes more economical to just install a 3sgte, or buy a whole turbo charged car.
Al-sw20 wrote:Road_Rebel wrote:So the GTE block has oil squirters?
even if you disregard labour charges since me, my dad and brother (both mechanics) will be doing the job?
planted1 wrote:Marf,
The 3SGE DOES have oil squirters
Road_Rebel wrote:Al-sw20 wrote:Road_Rebel wrote:So the GTE block has oil squirters?
Might be economical then.
I guess it depends if you want to be different or if you want real performance?
Different definitely and also i believe it would be more "driveable" (if thats even a word haha)
Driveable meaning slow?
