I have removed the door card using the method in Stephen mason guide in his link but I'm stuck.
Should I leave this in place as the air from the back of the speaker is causing this to vibrate more.
Do I need to show a pic or is this standard on a rev 5.
Also I have noticed that his guide used 1/2 inch MDF for spacers would 3/4 inch MDF be ok as I already have some so could start cutting the spacers straight away.
Where is the cross over on the car can I just use the existing wiring for speakers straight from the head unit and use the existing tweeter and crossover or would it be best to replace it all with something better?
It says to cut the shroud but what is this.
I have seen others say they they put the crossover in a bag and seal it with cable ties below the handle.
