Have tried chiselling off the shroud part but they're so soft that a hammered on socket won't grip.
Cheers,
Jon
jon_st205 wrote:Cheers they're 17mm once the shroud is gone.
kevin..in wrote:jon_st205 wrote:Cheers they're 17mm once the shroud is gone.
19mm one should do the job no probs then, I have a set of these and they are quality kit, bite into studs/rounded nuts brilliantly
elbon50 wrote:kevin..in wrote:jon_st205 wrote:Cheers they're 17mm once the shroud is gone.
I now have a set of those
Am sure they'll be very useful but the largest(19mill) one is not large enough for the wheelnuts
jon_st205 wrote:Aye, my ones are definitely a 17mm diameter circle with the shroud knocked off; remember these are the lockers so don't have flats on.
My set is supposed to turn up tomorrow![]()
SuperRedMR2 wrote:Extreme solution would be to weld a nut on the nut and then undo it that way.
jon_st205 wrote:Yep actually I used the 11/16th's which was a perfect fit, 2 minutes later two'orrible locking nuts removed.
Good tools, cheers Kev
kevin..in wrote:jon_st205 wrote:Yep actually I used the 11/16th's which was a perfect fit, 2 minutes later two'orrible locking nuts removed.
they are so good i even bought a set with my own money![]()
