Slipping Clutch
elbon50
Slipping Clutch
Post by elbon50 »
My clutch is slipping :!: :!:
Arrggghh ](*,) ](*,) ](*,)
SuperRedMR2
Re: Slipping Clutch
Post by SuperRedMR2 »
And? Buy another one and fit it. Job done.
Moustachio
Re: Slipping Clutch
Post by Moustachio »
my money is on the slave cylinder
Bring back Psygnosis
Peter Gidden
Re: Slipping Clutch
Post by Peter Gidden »
Moustachio wrote:my money is on the slave cylinder
Interesting :-k
SuperRedMR2
Re: Slipping Clutch
I've never experienced a slipping clutch in the mk1 - both of mine just suddenly went and exploded. Dowels, springs and inner of the clutch disintegrated :thumleft:
elbon50
Re: Slipping Clutch
Post by elbon50 »
Tell me more please Moustachio
What makes you say that :?:
Slipping clutches I've dealt with in the past required centre & pressure plates replacing
User avatar
Lauren
Re: Slipping Clutch
Post by Lauren »
It'll only be an issue if the slave isn't releasing properly, but that is very easy to check.
Most likely new clutch required though, a slipping clutch is fairly obvious really I agree.
un1eash
Re: Slipping Clutch
Post by un1eash »
It's a pretty easy job if u have access to ramps, mine was slipping in high gears so I replaced before it went.
PW@Woodsport
Re: Slipping Clutch
Post by PW@Woodsport »
A slipping Mr2 clutch spotted earlier today....
Hope that helps. :thumleft:
SuperRedMR2
Re: Slipping Clutch
This is a broken clutch
elbon50
Re: Slipping Clutch
Post by elbon50 »
un1eash wrote:It's a pretty easy job if u have access to ramps, mine was slipping in high gears so I replaced before it went.
Have ramps & a good pair of axle stands
Usually put the front on the ramps
Changed the gearbox a few years ago
Will make sure slave isn't sticking first
Noticed slipping going up a slope in top gear first
Now it slips in any gear on the level & getting worse
Engine will go from low revs to 6K without any change in road speed :(
SuperRedMR2
Re: Slipping Clutch
That is about to completely go - new one needed
elbon50
Re: Slipping Clutch
Post by elbon50 »
PW@Woodsport wrote:A slipping Mr2 clutch spotted earlier today....
Image Replaced With URL For Quote http://www3.telus.net/public/redenbac/images/discA.JPG
Yes, bet my centreplate is similar to that one Paul
un1eash
Re: Slipping Clutch
Post by un1eash »
This is what mine would do, swapped it out in 3-4 hours following the haynes manual. Only mistake i did was to pump the clutch after with the slave bleed valve open (put new fluid in aswell), i got the master cylinder rod stuck and was lucky that compressed air popped it back out without blowing the seals.
My clutch kit was an Aisin one, same as the one that came out but the new one the springs rattle sometimes which can be annoying.
elbon50
Re: Slipping Clutch
Post by elbon50 »
That was an impressively speedy job Un1eash :thumleft:
Seem to remember it took days when I changed the gearbox
I did clean, rust treat, red oxide & black gloss all the brackets, etc though :)
I have a complete Toda sports clutch here to go on so hoping that will be OK
Was your pressure plate damaged or was it just the centre plate linings worn away like the pic Paul put on here ?
kaiowas
Re: Slipping Clutch
Post by kaiowas »
It gets easier with practice :p
Gearbox out and back in again within half a day is easily doable once you've done it a few times and that's having to do it on the driveway. If you had a proper lift etc it'd be even easier.
elbon50
Re: Slipping Clutch
Post by elbon50 »
kaiowas wrote:It gets easier with practice :p
Yes, I'm a tad slow these days :)
It seems to be giving off a smell
Burning linings I think but doesn't smell like burning clutches used to
un1eash
Re: Slipping Clutch
Post by un1eash »
My pressure plate and clutch was in better condition then in Pauls picture, the Kit which i paid around £80 for had a new pressure plate, clutch and bearing in it.
SuperRedMR2
Re: Slipping Clutch
I recently bought a new fensport clutch for £113 including postage
elbon50
Re: Slipping Clutch
Post by elbon50 »
SuperRedMR2 wrote:I recently bought a new fensport clutch for £113 including postage
Seems reasonable for Fensport Alex
Mine includes a lighter flywheel
:-$ don't tell Tim, he'll have one of his turns :shock:
