If it connects to the cigarette lighter, then you can just go straight to a 12v source instead.
Make sure you install a fuse though.
How are you planning on connecting this up to your car stereo? Do you have an aftermarket one? If not, then its unlikely that you'll have aux inputs for alternative audio sources.
You need a stereo with stereo phono
inputs![](./images/smilies/spacer.gif)
a lot only have then as
outputs![](./images/smilies/spacer.gif)
You'll then need an xbox av cable
(left
& right audio
+ composite), connect the left and right phonos into the aux inputs on the stereo.
and the composite video cable to the input on the screen.
You'll get the xbox video through the screen, and if you turn your stereo to aux, you'll get the xbox sound.
Make sure you earth the xbox chassis to the car, i've had problems with noise from xboxes in cars before and have traced the problem to that on several occasions
(the don't generally earth properly through the power invertor).
