I have DIYd my alarm in the past, basically because the
'thatcham certified' installation wasn't worth the paper it was written on!
You will need to get the installation manual for the alarm, which details what the wires do and how to connect them.
Alarms usually don't ship with these manuals, they are for the installers eyes only.
However you can usually find them with the minimum of googling.
The actual
(2 or 4 depending whether the circuit in the alarm is single or dual) immobiliser wires will be black, so you will need to note where they came from and connect your new alarm up in the same way
(same polarity and direction in the circuit).
It's not that hard to be honest, no more difficult than installing an EBC or a complicated car stereo setup.
A wiring diagram of the car would be helpful but there are plenty of people on here that can help you out with which wires you need to interrupt, if you can't figure it out yourself.
Of course, you could just try replacing the battery in your fob and extending the aerial on your existing alarm unit
