[Mk2] [NA] cold start switch
im having cold start probs, i have to keep reving it til its warm or it cuts out, if i unplug the cold start switch and bridge the terminals in the plug it should work as normal ie turn on the cold start injector, if it doesent then does that meen the injector needs replacing?
Re: [Mk2] [NA] cold start switch
It's a bit wierd that one...I had to replace the cold start switch on my rev2 tubby...when it finally gave up the ghost, my car was overfuelling soo much I couldn't start it...also the cold start injector can leak causing overfuelling or erratic behaviour maybe.
I now leave the injector unplugged in the warmer months and plug it back in when it's cold...I found that unplugging the sensor caused running/idling probs.
