[Mk2] [Turbo] led dash lights
Am i right in thinking the above
(10-20 quid ebay) are just little leds you can buy from countless shops for pence.or am i missing something?
Re: [Mk2] [Turbo] led dash lights
andya24 wrote:Am i right in thinking the above(10-20 quid ebay) are just little leds you can buy from countless shops for pence.or am i missing something?
Just buy them in
If I remember rightly they are the same fitting as the side lights.
Get ones with about 5 leds on the one do that it spreads out otherwise you just get very bright little areas.![](./images/smilies/spacer.gif)
mrfil13 wrote:If I remember rightly they are the same fitting as the side lights.Get ones with about 5 leds on the one do that it spreads out otherwise you just get very bright little areas.
Exactly, tried a few in kine but the cheapest red ones I had look the best, just need 4 of them.
Any soldering required or just push in?
andya24 wrote:Any soldering required or just push in?
Just push in.
![Wink :wink:](./images/smilies/icon_wink.gif)
Wish id took a pic the other day phil of my wiring,you would of loved it,stripped it out and couldnt work out how to put it back,leaving it for peter next time!
andya24 wrote:Wish id took a pic the other day phil of my wiring,you would of loved it,stripped it out and couldnt work out how to put it back,leaving it for peter next time!
Worrying isn't it
![Brick wall ](*,)](./images/smilies/eusa_wall.gif)
Mine's less than perfect, however I'm trying to work through it one step at a time.
In terms of these dash LEDs though, it's a simple job.
If you need any help give me a shout
Very worrying!
Cheers bud
Cheers bud
