Oil in spark plug sockets
I did a service on my 3SGTE yesterday and there was about 30mm of oil in the spark plug sockets on cylinders 2 and 4 before I removed the plugs. I was guessing it was the socket seals on the cam cover but wondered if anyone had found another reason for it?
Re: Oil in spark plug sockets
cam cover gasket, it comes in two parts, the second part goes around cylinder 2 and 3 spark plug
Mr2 Rev1 tubby
http://www.imoc.co.uk/forums/garage.php ... e&CID=4217
my build thread
my build thread
Second that, happened on my na, changed the gaskets, about £20 and problem solved...
4ndee wrote:cam cover gasket, it comes in two parts, the second part goes around cylinder 2 and 3 spark plug
+1
RedMR² wrote:4ndee wrote:cam cover gasket, it comes in two parts, the second part goes around cylinder 2 and 3 spark plug
+1
+2
Thanks lads, I will get one ordered up.
you will need to put a pea sized blob of silicone in the cam corners or it'll leak from there...you more than likely see the stuff when you remove the old gasket.
