Hi all, I currently have a Dastek Unichip piggyback ECU and I'm looking to upgrade to a full standalone system.
Can anyone recommend a company and a system to get to supply, fit and mapping thats good value for money, I don't want to spend ridiculous amounts on this.
Any Affilliates doing good deals on this sort of thing just now? I'm willing to travel to get it done properly.
Cheers, michael.
[Mk2] [Turbo] Best value standalone ECU?
Re: [Mk2] [Turbo] Best value standalone ECU?
Gotta be the Power FC hasn't it? mapping costs are expected to be around £300 for the amount of time it takes to do...of course if the car isn't in tip top condition elsewhere then it will have to be sorted before mapping takes place...or it'll be back and fro.
djpkins wrote:Gotta be the Power FC hasn't it?
+1
There are a lot of capable standalone ECU's on the market, the thing that makes the difference is the mapping. I would always choose who is going to map the car first and then go with their preferred choice of ECU.
Ryan G at 2Bar Tuning has a very good reputation on many car forums, he can map different ECU's, his ECU of choice is the Syvecs. If it was me I would contact Ryan to discuss, contact details here: http://www.2bartuning.com/#/what-we-offer/4526900196
Peter Gidden - SBITS wrote:djpkins wrote:Gotta be the Power FC hasn't it?
+1
+2
Seems the Apexi is winning this then, thought that would be the case.
Can these still be bought new? If not, where else can I buy one?
Been looking on E-bay but can't see anything good. Do they need to be specifically for the sw20 or would another one work?
Sorry for all the daft questions!
cheers, Michael.
cheers, Michael.
msherry21 wrote:Seems the Apexi is winning this then, thought that would be the case.
cheers, Michael.
I think they are now discontinued but occasionally come up for sale second hand and the going rate is around £500-£600.
You would need an MR2 and revision specific ECU, yes.
Is the link range of ECU's good value? I beleive they are pretty much plug and play with a base map.
I went Megasquirt but would not recomend this as good value, if you want a supplied and fitted service then its out all together. Find someone truested locally as if you go to far a feild it will cost you if something is not 100% when its fitted and you have to go back and forth a few times.
I have a AEM sitting around if your interested? Is as good as new with box, disc and a map from Ryan G on it.
Hi Olly, please PM me details and a price and we'll see if we can sort something out. Cheers.
Michael.
Michael.
I'd be interested in the AEM too, if the OP isn't of course
Ok mate. Second dibs for you.
You know what.. i think im going to have to disagree with the Apexi PFC being a good value budget ECU! It has gone up in price loads since they stopped making them, they use quite dated technology when compared to modern ECUs and lack a lot of features and requires additional tuning interfaces to tune it!
I know i got a good deal here but just an example of what you could get if you look hard enough... I got a LinkPlus G3 XLEM (the top of the range G3 -same as what nathan used on his 900bhp record breaker) which uses a USB connection and 32-bit windows mapping interface, has lots of features like launch control, flat shift, anti-lag, has half a million digital and analogue inputs and outputs and can drive COPs straight from the box! Also a 7-bar Link map sensor and the P&P loom all for only £650! (2nd hand obv) this ecu is miles ahead of the PFC and i got it for what...£50 more?!
RyanRs wrote:You know what.. i think im going to have to disagree with the Apexi PFC being a good value budget ECU! It has gone up in price loads since they stopped making them, they use quite dated technology when compared to modern ECUs and lack a lot of features and requires additional tuning interfaces to tune it!
But the PFC is plug & play, and you can get a 2nd hand one for £500. Wasnt this used on Shahids car which made over 900bhp as well?
Link is practically plug and play nowadays too, £80 for a loom adapter and good tuners like Ryan.G etc will have the car running in no time. Took Ryan 10 min to wire in my link and get the car running good enough to drive it in to the dyno for mapping, 45 min later and i was driving home with just under 380fwhp! End of the day, AFAIK the self tune on the PFC is not designed to be used as a permanent tune, but as a starting point so the car can be driven to the rolling road to be tuned properly; if you had a Link and an adapter then whats the difference in just driving to the rolling road on the stock ecu and plugging the Link in when you get there!
RyanRs wrote:Link is practically plug and play nowadays too, £80 for a loom adapter and good tuners like Ryan.G etc will have the car running in no time. Took Ryan 10 min to wire in my link and get the car running good enough to drive it in to the dyno for mapping, 45 min later and i was driving home with just under 380fwhp! End of the day, AFAIK the self tune on the PFC is not designed to be used as a permanent tune, but as a starting point so the car can be driven to the rolling road to be tuned properly; if you had a Link and an adapter then whats the difference in just driving to the rolling road on the stock ecu and plugging the Link in when you get there!
You defo got the Link as a bit of a bargain there! The PFC will do the OP fine though, as hes not going over 320bhp?
It sounds like the "Link G3" and the "Power FC" are the ones to go for then. How much does a basic Link system cost and where from?
I'm just looking for a reliable standalone that will work nicely with my car. I'm not fussed about the power too much at the moment. It was running 320bhp approx with the Unichip before the rebuild and that was great! I just wish I could get that mapped again and save myself a small fortune, seems like nobody maps them anymore!!
Cheers, Michael.
Cheers, Michael.
IIRC, the Link G3 is no longer made. Last S/H one I saw with plug and play adaptor was about £650.
As already said, S/H PowerFC is about £500, and easier to find.
Who is going to map the car? That's where I'd start.
