Just done a compression test on my rev 3 turbo and I have 120psi across all four cylinders ! Does this seem abit low or does it only matter when there is a difference across the cylinders ?
[Mk2] [Turbo] Compression test results
Mr2 Rev3 Turbo
Re: [Mk2] [Turbo] Compression test results
Well, an indifference will point to a suspect cylinder/cylinders but yours do seem to be low across the board..
Did you have the throttle wide open? If so, it might be worth putting a few drops of oil into each cylinder in turn and repeating the test. It'll show up if you have worn rings/bores as the pressures will go up after the oil seals the bores.
No I didn't do it with throttle wide open, redone with with throttle wide open and got 150 across all four ? What would this suggest then? Should I do it with throttle wide open and oil in see If that makes a difference
Mr2 Rev3 Turbo
Just put oil in cylinders and it's 150 across all four regardless of throttle open or not ?
Mr2 Rev3 Turbo
What an engine scores on a compression test is largely irrelevent, its the difference between the numbers that tell the story. All 4 the same is spot on and better than I have ever seen.
Workshop manual says min comp is 128 psi how come compression goes up with throttle open ?
Mr2 Rev3 Turbo
garry goodall wrote:Workshop manual says min comp is 128 psi how come compression goes up with throttle open ?
Air can get in to the cylinders.
Did you do it with the engine warm?
150 across all 4 pots is fine though.
TOTB 2010 Rwd top speed, 1/4 and shootout winner.
10.7@142 on R888 street tyres, 10.3@134mph on slicks,
9's on slicks to come, with a clean full throttle pass! Goal of 0-150mph in a 1/4 of a mile....
