[Mk2] [Turbo] Audio Wiring.
Navz
Post by Navz »
Hi all,
Do you know if there is a space on the passenger side footwell going into the front trunk?
I want to run my RCAs and speaker wires through the passenger side if possible rather than the drivers side.
If you can help that would be awesome.
madbasshunter
Re: [Mk2] [Turbo] Audio Wiring.
Post by madbasshunter »
Have you got aircon ? As I use the holes for the aircon on the passenger side quite often.
Navz
Post by Navz »
yes i have aircon, even though it never works.
madbasshunter
Navz wrote:yes i have aircon, even though it never works.
Remove it I did which left a nice route for the wiring, then I ripped it all out and put the amps in the boot which is a better place :)
loudandproud205
IMOC Organiser
Post by loudandproud205 »
Yes you can its double skinned and the gromet it a pain but its do able
Got boost?
Kinda!!!
0.3 bar FTL
Neil_turbo
Post by Neil_turbo »
Without having a mk2 around I can't be 100%, but I am pretty sure there is.
If not then there should be one in the middle.
Probably easier to check from the frunk side though!
Edit - typed this last night and only just submitted! Doh!
Return to “ICE and Security”
