[Mk2] [Generic] New Rebuidable OEM Struts?
msherry21
Post by msherry21 »
Hi everyone. I'm about to change my suspension as my Tein HA's are stuffed.
I was thinking of buying some new rebuildable struts with Eibach springs, Are these struts/shocks any good? I know later on I can replace the struts with Koni's...but for now, are the standard shocks and struts good enough for back road and occasional track use?
I really appreciate any info on this.
Cheers, Michael.
HighwayStar
Re: [Mk2] [Generic] New Rebuidable OEM Struts?
Post by HighwayStar »
Not sure if you can actually still buy new rebuildable struts. Think you may have to buy secondhand and refurb.... Eibachs supposedly quite comfortable but maybe not a lot lower than a stock rev3 ride height. Best combo depends on budget and requirements... what are yours?
R.
uglee
Post by uglee »
I'm sure the new Turbo struts (not Bilsteins) I got from Trevor at TCB parts were rebuildable. I remember looking at them and seeing the retaining collar that unscrews and thinking it would be handy come replacement time for some KONIs.
HTH
raptor95GTS
Post by raptor95GTS »
uk n/a struts are all rebuilding IIRC
Peter Gidden
Post by Peter Gidden »
allan welsh wrote:uk n/a struts are all rebuilding IIRC
Rogue
Post by Rogue »
*New* UK struts from Toyota are no longer rebuildable.
Hez
Post by Hez »
Sorry to hijack, are the uk n/a rebuildable struts exactly the same across the range and also the same as the rev1 turbo struts.
Peter Gidden
Hez wrote:Sorry to hijack, are the uk n/a rebuildable struts exactly the same across the range and also the same as the rev1 turbo struts.
They're all the same dimensionally, so interchangable. I suspect they are very similar if not identical in spec., but who knows - there is no public comparison data of Toyota OEM struts. (Obviously excluding Bilsteins).
JDM struts are not rebuildable.
Hez
Post by Hez »
Reason i ask is i got coilovers on mine and its too much for roads round here got no teeth left and never sees a trackday anyway.
So i can get some uk rebuildables drop in some adjustable dampers and lowering springs and it would be ok on a rev3 turbo?
msherry21
Post by msherry21 »
Yep, thats exactly what I'm doing.
Cheers.
Peter Gidden
Yep. As msherry says, good solution.
Some old UK struts off ebay, a nice shiny Koni kit, job done.
Hez
Post by Hez »
Cheers for that peter and msherry think thats the way forward then :thumleft:
Peter Gidden
Hez wrote:Cheers for that peter and msherry think thats the way forward then :thumleft:
For Koni SSK, give Dan a call at dcperformance.co.uk. Price guarantee, and great service.
