After having the engine out and had a full service about 4 months ago there has been an annoying squeal coming from the alternator.
I checked the alt had free play when the engine was out so I could change it if needed but was fine so thought all would be good.
To reduce drag I had the aircon pump removed and thus had a belt spare from the work done which is a 4pk875.
I was just wondering is someone could tell me if the squeal is due to the air con belt on the alternator or is the squeal due to oil on the belt while fitting or something?
Oh and the alternator belt has been tightened about 5 times now and still has the annoying sound
(only for about a minute after a cold start)
Any help is much appreciated
