replacing the exhausts on a stock car for a larger free flowing one doesnt actually ad any performance, you lose back pressure and gain noise.
if weight saving is the venture then lose the big heavy back box and replace with some lighter smaller ones, will sure sound different.
more free flowing exhausts on a turbo is usually a good idea, but sometimes if you go for too big pipe diameter you lose back pressure and cause the turbo to over boost.
which could cause a massive boost spike and help in killing the engine.
