yes.
.only slackened off the rear of the 2 star drive cap bolts.
.all of the faces are clean and free from dirt, just very clean, fresh oil dribbling onto the gearbox.
.removed the lower 2, 14mm bolts and then pulled the dizzy out.
I wiped all the surfaces with some white spirit to further de-grease and applied a thin bead of high temp black silicone around the dizzy neck, behind the o-ring
( outer side
.it's stopped the leak for now.
I have a spare dizzy, but it too refuses to be clamped down by the cap, my thoughts are that I have contaminated the gap between the cap surfaces when cleaning it out, maybe a feeler guage will slide inbetween them and move the blockage.
.should the dizzy be
"locked into place" with the cap or should it still be moveable?
