When I give it put my foot down, the speedo has started to shoot up to say 50 if I am doing 30? Is this a sensor issue of some kind?
It just jumps up and down, all over the place when the accelrator is pressed.
Any ideas?
[Mk2] [Turbo] Speedo goes up when I accelerate..........................
Re: [Mk2] [Turbo] Speedo goes up when I accelerate..........................
I was going to come back with some sarky comment like..
"what did you expect durrr"
But on a more serious not..
gearbox speedo sensor gone..
Thanks - thought it would be that, where is the best place to order one from?
willfinch36 wrote:Thanks - thought it would be that, where is the best place to order one from?
Probably toyota.. I think mine has gone also.. won't get round to sorting it till next year though.
I have a used one for sale, £40 delivered
! Someone else with this problem! I've been driving for ages knowing that my 30mph is actually 20mph, compared against several factory friends cars + GPS etc etc. Well, time for a new sensor I guess
check the connector on top of the speedo sender on the gearbox, it is know to collect water and connections perish and cause the same results, had that on my celica, also if its an import, then check behind the clocks for a converter chip, a loose wire can cause same too
