3SGTE sprint & Track mk1 build
Re: 3SGTE sprint & Track mk1 build
I just started a thread on data loggers. What are you using?
i am using one that Mark built....
http://www.imoc.co.uk/forums/viewtopic. ... ata+logger
will be setting up a few k-types, so can monitor intercooler efficiency as well as oil and coolant temp accurately
Incredible build Neil, enjoyed reading through...
hats-off to you!
hats-off to you!
Bring back Psygnosis
thanks was worth the time typing up then!
Should hopefully really come together over the next few months ready for the 2012 season!
have just finished a few interior mods... all adding to that all important racey look..
Cluster above the screen is ACC, ON and push start. has a neat function where after switching the ON switch, the button will flash for 20 seconds, after this if the engine has not been started, you have to start the sequence again. stops it accidentally being pressed once running!
switch next to it is for intercooler and engine bay fans, switching between either ACC or overide when engine is off
Blue switch is the 10 position motec map controller, at the moment controls boost etc
red button below is calibration for the wideband o2 gauge
Buttons below and screen are the datalogger controls and display
Back looks like this...
milling the carbon panel
If you need any more carbon sheet Neil let me know!
platmatt8 wrote:Lauren has got bigger balls than most men on this site
charged wrote:Mine's probably screaming 'stop raping me'
Yes I do please Alex! Will drop you a pm in the new year!
From personal experience, you want that O2 sensor calibration button well out of reach of the driver. It's very easily pressed by accident and if you're driving then your calibration (and presumably O2 feedback trim) turns to crap!
Makes sense, cheers Patrick!
I havent upgraded the Motec to pro yet, hence wideband isnt feeding the ECU, so only issue of accidentally touching would be the display above reading incorrect.
Will be worth considering for when i do get round to it though.
Brilliant write up Neil and a awesome piece of kit having seen it in the flesh, very impressive, hats off to you
Neil_turbo wrote:i am using one that Mark built....
Did you build it yourself, or buy it pre-built?
I've got one lying around as well, just never got around to building it
SW20 Rev1 Supercharged 2GR-FE Powered Trackday Car.
- Lauren
- IMOC Committee
Mark (my fiancee) custom made the dataloggers from his own design. He designed it from scratch and had PCU boards printed and assembled everything as well as writing all the code. So the datalogger is not a 'kit' you can buy and build yourself. Mark sold about 5 of them IIRC, this was year ago.
2020 GR Yaris - Circuit Pack
Lauren wrote:Mark (my fiancee) custom made the dataloggers from his own design. He designed it from scratch and had PCU boards printed and assembled everything as well as writing all the code. So the datalogger is not a 'kit' you can buy and build yourself. Mark sold about 5 of them IIRC, this was year ago.
Phew ! Didn't realise that Mark is quite as clever as that Lauren
Wish I could do similar
Happy Christmas
Peter
- Lauren
- IMOC Committee
LOL, Peter!
Mark is not only a bit of an electronics geek, he also is a founder member of IMOC and the SC guru!
A merry xmas to you too.
was reading a few days ago Lauren Mark's rebuild guide for the AGZE i think it was, cracking read, but did he stick to budget?
Alex
Alex
- Lauren
- IMOC Committee
Think he spent around £1500 on parts, which were all OEM from Toyota. This is the engine that's going in my AE86.
All my fault of course for blowing it up at Elvington.
I know, I bought one from him.
- Lauren
- IMOC Committee
Ah, it was you, was thinking, but couldn't remember!
Still, nice to see that of the 5 odd he sold that at least Neil's will now actually be used!
Nice car Neil, lot of effort gone in there! You should be proud of it! I know I would be
Thanks everyone, couldn't even count the amount of hours gone into this thing!
Took it out and up to full boost for the first time in around 4 months today! forgot just how quick / scary this thing is, really do need to focus my driving for next years sprinting.
Mark helped me loads with the datalogger, wired up the new huge screen i bought from America and made the button board for me, milling was done at his workshop, also programmed me a special start up sequence....
