Hello all,
On my Mk3 I've got the silver fitting lock down brackets so am assuming that the previous owner had a hard top...
http://www.spydermagazine.com/2000/Oct/ ... ardtop.htm
I'm trying to get one for mine so the question is this: Will a hard top simply fit onto my car or will I require something else? (I'll take pictures)
Apparently here are the parts required:
Side Panels RH 62511-07090 £58.42
Side Panels LH 62512-17080 £58.44
Locking Post 69431-17011 £60.05
Locking Post 69432-17011 £60.05
Lockdown Bracket 58395-17020 £19.23
Lockdown Bracket 58396-17020 £19.23
Defroster Cable 82187-17030 £10.51
Plate Cover Hook 69341-17010 £14.22
Plate Cover Hook 69342-17010 £14.22
Cover Plug 63259-17010 £22.56
Seat Belt Lower Bolt 90109-11040 £?
I'll have a look at the side panels tomorrow...
Hard top
Re: Hard top
The only things you need are the locking posts and the defroster cable. You can cut your existing side panels (they're already marked) and the rest isn't needed.
Word
A ha! The two black plastic thingies that that were for for sale in another auction...
Thank you very much Ekona
