All in a bit of a random order but...
There's the 3 obvious bolts along the top of the wing once you open the bonnet (remove these last)
If you remove the headlamp surround there is another 3 highlighted by the green arrows
Youll also have to remove the front trim strip so remove the front sidelight cluster
and unscrew the screw holding it in.
Undo the screw that is now exposed then th eunit can be pulled out.
and round the back theres 2 nuts holding the strip on (youll need to remove the wheel arch liner to do this.
Theres also a bananna shaped bracket holding the front of the wing to the bumper that needs to be undone using a socket (not got a pic)
At the bottom of the wing is also a bolt securing bottom of wing plus if you open the door wide and look inside the A post theres a nbolt there too.
Partway down the back of the wing is another bolt (youll need the wheel arch liner removed) which needs undoing too
Theres a few wires and stuff so be careful and dont forget to pop your side repeater out or at least twist and remove bulb
