Rogue wrote:Sounds like you've lost the blades from the exhaust side of the turbo..
bluesmoke wrote:Rogue wrote:Sounds like you've lost the blades from the exhaust side of the turbo..
Jesus, how can I work out whether it's this or a leak?
EDIT: And what would cause this?
T.F.S. wrote:bluesmoke wrote:Rogue wrote:Sounds like you've lost the blades from the exhaust side of the turbo..
remove air filter and put hand over inlet to block air flow with engine running..
.a big leak will let the car run, a small leak will howl like a b1tch and if theres no leak it will stall within a couple of seconds
whilst you are there have a feel of the turbo shaft, but obviously do that with the engine off..
rev3turbo wrote:if it is the worst outcome, ive a good ct20 turbo for sale
2mad wrote:Hi,
That is the sound of a broken turbine wheel![]()
when you get the turbo off the car I would expect to see the turbine wheel still in place but the fins all smashed up.
Hope you get it sorted soon,
Kev.
