Hi all I am wanting some pics of the Hi spec sva rear caliper conversion
and what price you paid and where did you get them ?
Ive sent several emails to hi -spec they keep quoting me fronts only
Cheers in advance !
[Mk2] [Turbo] Hi spec rear brake owners Wanted!!
Re: [Mk2] [Turbo] Hi spec rear brake owners Wanted!!
ive got monster 4 pots on the back with handbrake connection if u want a pic of that?(360disc)
i know that car from somewhere!
Please mate are you running them 18's ??
hi spec
heres a quick pic with wheel on
iv got to take em off today so il get a pic from under car showing inside/handbrake connection if thats wot ur after.
i got em off an imoc member, in fact u showed me a picture of em before i had collected them from him.
yeah im running them 18"s and they just clear front and back with a bit of work and spacering
Oh yeah , How you doing M8 did you get home ok?
cheers for the pic have you put the wolfkatz 1" master cylinder on
i am looking to get the master cylinder upgrade as pedal tavel is quite substantial.
how did you get home?
nice rear brake setup, that's a big disc too!
I have 6 pot 330mm fronts and the 4pot 300mm at the back with the sva cable handbrake.
Bought them from Hispec direct as I only live about 5 miles away from them.
I've tried to keep the front to rear brake balance as good as possible.
They've been round the ring very recently and did an epic job and seemed to just get better and better as the day went on. I have Ferrodo DS2500 pads as well.
Still the standard master cylinder - could do with an upgrade but they're not overly long or squishy.
What do you wanna know?
How much did you pay for the rears if you dont mind me asking?
also is the handbrake fit for purpose ??
Paid whatever the list price was for them back in January/Feb. (A lot).
The handbrake needs adjusting well to make it work well but it passed the mot no problems etc so can't be that bad. I wouldn't leave it on a massive hill without the car in gear but I've no problems just pulling it up and leaving it. It's got better over time as well which is weird. Cables need tightening after about a month.
I have some pics somewhere, pm me your email and I'll send them if you want.
i have 8 pot calipers 330mm discs front with standard caliper moved out at the rear ,i would like 6 pot rears but all the ones i see lose the handbrake & you have to fit a hydraulic handbrake which is a M.O.T failure,so what kit are you guys running if you still have a cable operated handbrake am interested to know
thanks nick
thanks nick
Cheers ye I know where hi spec is I used to work just up the road at whitehouse Toyota just wanted to know how hi spec done it !! I don't want them as I want to match my 8 k sports on the front , the 6 pot k sport rears require a hydraulic handbrake
tarmac terrorist wrote:Cheers ye I know where hi spec is I used to work just up the road at whitehouse Toyota just wanted to know how hi spec done it !! I don't want them as I want to match my 8 k sports on the front , the 6 pot k sport rears require a hydraulic handbrake
By using a cable. Look on their website - it's not too hard.
http://www.hispecbrake.co.uk/
pnicho wrote:tarmac terrorist wrote:Cheers ye I know where hi spec is I used to work just up the road at whitehouse Toyota just wanted to know how hi spec done it !! I don't want them as I want to match my 8 pot k sports on the front , the 6 pot k sport rears require a hydraulic handbrake
looking at there web site you buy a seperate caliper same ide as some porsche & ferraris
not to bad either at £65.00 + vat each time to start saving for me k sport 6 pots
No you don't.
They have a built in handbrake caliper on the main caliper that has a seperate mechanism and pads for the handbrake. The spot caliper is not what this thread is about and I wouldn't use that with a K-sport caliper as you don't know where the mounting points will be.
This is what we're on about.
http://www.hispecbrake.co.uk/Rear%20SVA ... 0PCD).html
I see ye that's a good idea unfortunately I want 6pot calipers & want them to be K sports , sorry for messing with this thread I will leave you alone now
