I wouldn't know about this fault if the cat warning light on the dash had not started coming on today.
I did change the clutch a week ago and am only an amateur so the experts here will know how many systems were disturbed.
First glance revealed a leaking nearside drive shaft oil seal but I think this is unrelated, having checked the box oil level and cleaned everything up.
I checked the fault codes and got 24 and 31, which are intake temp and pressure sensors I believe.
Further investigation, the charcoal canister
I pulled the ECU fuse for a few minutes and still getting codes 24 and 31.
The car seems to drive fine but I'd like to be sure.
