[Mk2] [Turbo] Turbo stud size
cantfindausername
Post by cantfindausername »
Just wondering if anyone has the measurements of the studs on the turbo for the downpipe?
Ant
***RIP Car13 ***
*** Now in an Evo ***
Driftlimits Performance
IMOC Affiliated Company
Re: [Mk2] [Turbo] Turbo stud size
M10x1.25
cantfindausername
Cheers Luke, it's the length I'm after specifically.
***RIP Car13 ***
djpkins
Post by djpkins »
total length...48mm, with the longer (20mm) section of thread sticking out...the nut shouldn't be on it, this is one i use for another purpose but it came from that ct26 in the pic.
cantfindausername
Perfect. Thanks for confirming. I'm assuming the ct20b would have the same studs - if someone could confirm.
***RIP Car13 ***
djpkins
Post by djpkins »
I took 2 out of this ct26 to put into my ct20...which is now on the car and fine. :thumleft:
cantfindausername
Cool. I actually need about 47mm so even I'd I have to trim these they should be fine.
Thanks for the info!
***RIP Car13 ***
