She is a rev2 running a CT20b, st205 CC, standard cat
Not very impressed with the numbers! Running
It really felt like it had more power, but there you go.
Power
![Image](http://i1197.photobucket.com/albums/aa429/jtz1979/power-tq.jpg)
Power
![Image](http://i1197.photobucket.com/albums/aa429/jtz1979/power-boost.jpg)
Slarty wrote:
it's just that we subscrible to the theory of hitting it harder until it works.Or something falls off, in which case you've hit it too hard.
Navz wrote:My standsrd rev 3 turbo engine with subtle mods(intercooler, exhaust,induction kit), and power fc is being dyno tuned next week I will post it up to give you a better idea for comparison.
cvega666 wrote:mk3 with a turbo kit= didn't run the full run because it was WAY too lean even off boost!
mrspete wrote:cvega666 wrote:mk3 with a turbo kit= didn't run the full run because it was WAY too lean even off boost!
The more I think about it the more confused I'm getting![]()
he could not fit the hose to my engine
?, the pipe up the exhaust only went up 6" on one of 4 outlets, how could he know I was running too lean
He basically only had the rollers to go by, how so howcould he know
cvega666 wrote:mrspete wrote:cvega666 wrote:mk3 with a turbo kit= didn't run the full run because it was WAY too lean even off boost!
he put a Lambda sensor into your exhaust, to monitor the air/fuel mixture.It looked like it was running way too lean, that's why he aborted the run, to prevent any damage.
Too lean
= melted pistons.
