Damaged Flywheel - where can I get a replacement quickly?
Jimbo_Jet
Post by Jimbo_Jet »
Got my car in the garage now having its slipping clutch replaced and I’ve just been told I need a new flywheel as my existing one has hairline cracks in.
First of all, does this usually happen and is it a problem? Secondly, where can I get a new flywheel from quickly as my car is stuck in the garage until I get another one? Can I use one from a MK1 breaker?
elbon50
Re: Damaged Flywheel - where can I get a replacement quickly?
Post by elbon50 »
Can't see why you shouldn't use a secondhand F/W Jimbo
Never heard anything about cracking though
Have you checked the For Sale section on here ?
Some members have fitted an alloy F/W & may have a standard one for sale
Peter
Jimbo_Jet
Post by Jimbo_Jet »
Thanks! Just been looking at them, was hoping to find a cheap lightened one in the UK somewhere but they'll all in the US :? and I need it asap.
Just found out that TCB parts have a used one in stock so they're digging it out to check the size. When you measure a flywheel is it to the end of the plate or to the end of the teeth around the perimeter?
LimeyMk1
Post by LimeyMk1 »
They need to measure the diameter of the smooth mating surface on the flywheel. Both mk1a and b flywheels are the same physical size.
Jimbo_Jet
Post by Jimbo_Jet »
Oh right, thanks! My garage has just come back to me and said 268mm to the outer perimeter, so it's the same for both?
Jimbo_Jet
Post by Jimbo_Jet »
- deleted - double post
LimeyMk1
Post by LimeyMk1 »
Jimbo_Jet wrote:Oh right, thanks! My garage has just come back to me and said 268mm to the outer perimeter, so it's the same for both?
Yep, you need the mating face which will be either 200 ish (mk1 a) or 215 ish (mk1 b).
You can fit either, just means you'd need to get a clutch to match.
Jimbo_Jet
Post by Jimbo_Jet »
Thanks, well I've got the 212 MK1b clutch to go in so now I know what I'm looking for!
Mk1Chris
Post by Mk1Chris »
£50??!! for a 20 plus year old flywheel, im in the wrong business.
You can have mine for free if you want to come and swap my nice new fidanza in for me :wink:
Smallport 4AGTE
elbon50
Post by elbon50 »
So what's this about hairline cracks Jimbo ?
Whereabouts on the F/W are they
Does anyone know the likely cause ?
Peter
SuperRedMR2
Post by SuperRedMR2 »
Don't look at cheap ally flywheels from the US they are xxxx.
I just bought a fidanza but got stung on import tax.
cartledge_uk
Post by cartledge_uk »
SuperRedMR2 wrote:Don't look at cheap ally flywheels from the US they are xxxx.
Do you have any proof of this? or is this your opinion? becuase such comments could be seen as libelous.
SuperRedMR2
Okay, they are xxxx from my opinion. I would rather spend £280 on a fidanza than one costing £111 from the states.
Jimbo_Jet
Post by Jimbo_Jet »
Just been shown my old flywheel while still on the car with an LED lamp. There are a dozen or so tiny, tiny, cracks the length of a small grain of rice, pointing away from the centre of the FW. They are in the matting surface of the fly where the clutch grips it.
He said he commonly sees this in Scooby's when he changes the clutch.
Wish I knew this was coming as I would have saved for a fidanza as can't afford the extra £220+ it would have cost on the second hand one I've just got. #-o
SuperRedMR2
Lol you could offer me £1000 for mine and have it tomorrow :P
elbon50
Post by elbon50 »
Jimbo_Jet wrote:Just been shown my old flywheel while still on the car with an LED lamp. There are a dozen or so tiny, tiny, cracks the length of a small grain of rice, pointing away from the centre of the FW. They are in the matting surface of the fly where the clutch grips it.
A lot of mechanics may have missed those tiny cracks Jimbo
Good job he'd seen it before on the Scoobys & knew what to look for
Stress cracking from sudden clutch engagement at high revs perhaps ?
Peter
Jimbo_Jet
Post by Jimbo_Jet »
That's not really my driving style but I do clutch slip in first a bit some times for a fast take off. But never rev it up and just drop the clutch.
Mind you, down changes at speed on B road balts have been crunchy or stiff for a year now until I had my master cylinder changed so maybe that did it?
elbon50
Post by elbon50 »
Jimbo_Jet wrote:That's not really my driving style but I do clutch slip in first a bit some times for a fast take off. But never rev it up and just drop the clutch.
Wondered if your car had been used on track
Perhaps by a previous owner ?
How long have you owned it ?
Have had mine getting on for 15 years now & things definately happened to it before. Some sort of accident, a respray, new w'screen to name a few :)
I love the little beast dearly nevertheless
Peter
