The only noise from my car now is the squeaky clutch pedal.
I know where it's comig from, the arm on the end of the cable.
I lube it up but it returns within a couple of hours.
Anyone know any good tricks or is it a case of waiting for the clutch to be changed???
It's annoying.
Squeeky clutch pedal
Re: Squeeky clutch pedal
shift at higher revs or crank the cd player up... sorry not useful but I have the same issue and even after changing the clutch it's still there. I ignore it now but wonder if it can be heard when I'm changing at the lights.....
mine also squeeks, i've learned to ignore it - pretty sure it can be heard outside
It's loud as xxxx from the outside.
Haha, same here! I've come to accept it as one of the "quirks" of the car now
blacker than the blackest black, TIMES INFINITY!
Its the bushing on the clutch release fork that squeak. When getting clutch done always ask them to lube it, mine was done and is silky smooth and silent now
Slarty wrote:
it's just that we subscrible to the theory of hitting it harder until it works. Or something falls off, in which case you've hit it too hard.
In my car it sounds like it's was coming directly from under the tunnel/middle of the car, so a bit far for the fork.. but could be it I guess
mine sounded like it came from the pedal itself. when the clutch was done i asked them where the squeak was and they said after following it (first thought it was pedal, then master cylinder) turned out it was the fork itself.
been silent ever since
hmm. Mabye ill have a look this weekend to see if i can stop the 2 sounding like a rusty old mattress!
g.lewarne wrote:Its the bushing on the clutch release fork that squeak. When getting clutch done always ask them to lube it, mine was done and is silky smooth and silent now
That is what fixed mine a few years back.
i hate squeaky clutch so embarising
My corolla t sport had a squeaky clutch it was the master cylinder bought a new one and that went just over 2 years later.
My mr2turbo had a squeaky clutch i got a new clutch and now it is squeaky free !
I've bloody got squeaky clutch now
Where on earth is this clutch release fork you speak of ?
Get under the car as if you were changing the old filter.
Get someone to press the clutch pedal and you will see the arm move and hear the squeek.
dazzz wrote:Get under the car as if you were changing the old filter.
Thank you, will try and do that tomorrow
