can someone please point me in the right direction to find some sump sealant that doesnt cost a arm and a leg please?
i have looked and looked but am not sure which ones are proven to work on our cars.
Peter G did suggest a brand to me today but i forgot its name!
raaaaaaaa
[Mk2] [Turbo] sump sealing
Re: [Mk2] [Turbo] sump sealing
you can buy the factory applied stuff from toyota and its not mega $$$$
As far as I'm aware, it's just an RTV (room temperature vulcanising) sealant? It should be pretty generic stuff....
Go down your local motorfactors and ask for a tube of Blue (make sure it's the non-hardening formula), job done
thanx guys
need something online as i cant use the car as the leak is that bad!
have done the job twice before, once with cork; that blew/squished out. once with rtv: epic failure on 2 counts.
flebay links?
blue ashman? brand ??
flebay links?
Something like this:
http://www.ebay.co.uk/itm/Hylomar-Unive ... 20b81561b3
Tips:
Do not use a gasket, or cork
Clean both edges thoroughly before attempting to seal it
Take several passes around the sump to tighten down, don't fully wind in each bolt on the first round
Wait a couple hours before fully tightening down- gives the sealant a chance to start going off before you fully tighten down and squish it all out of the joint
Tips:
spoolfool wrote:Peter G did suggest a brand to me today but i forgot its name!
raaaaaaaa
We've used this one for years:
http://www.ebay.co.uk/itm/WYNNS-BLACK-R ... 20b9a3ccf8
spot on. thank you
ash that was a sneaky edit i didn't see that before i did the job. ne mind.
i put a fair bead on let it sit for half hour then whacked it on. i did everything as in your edit except waiting coupe of hours ( as i never saw ya edit).
i have however left sump plug out to help it go off (peter suggested this but as i see he uses a different product). guess i will fill her up day after tom.
fingers crossed, am fed up of doing this bloody job without a ramp!
Apologies
The only thing I would have done differently is not waited half an hour before whacking the sump on, I'd have put it on and partially tightened down to spread the blue, left it for a while and then fully tightened down
Fingers crossed for you bud
yeah, oh well. it only formed a slight skin think maybe as it spread it tacked on!
thanx for help guys!
sorry ash, epic failure lol. i left a 60 quid, 20 mile oil slick round the Cotswold's, oooopppppps!
when i took the blue off it hadn't stuck to anything. it was still the consistency of hair gel
re done it today with peters suggestion and it seems fine now. fingers still crossed though
Damn mate...not good
Wonder what you've got on your sump that's stopping it sealing??
I've used blue to seal the sump on a good few builds now and never had any issues at all
Hope it's sorted now...
I wonder if leaving it for half an hour before you closed the joint coked things up
the sump pan face is likely not flat.
hi the ebay link as gone which sealer was it please?
- IMOC Affiliated Company
I usually use blue when fuel is involved, silicone is the way.
For best results, "clean" = spotless. Acetone or panel wipe on both surfaces will do the best job.
Has anyone got another link to what Peter put or the name of it ?
Wathall wrote:Has anyone got another link to what Peter put or the name of it ?
Dirko S
http://www.ebay.co.uk/itm/Dirko-S-Profi ... MR:GB:1123
Clean surfaces and then degrease with thinners. Ensure spotless and dry.
Apply sealant and allow to part cure.
Put parts together and nip bolts. Leave an hour then torque to spec.
Leave sump plug out and allow to fully cure for 24 hours before filling with oil.
Sealant and method advised by top motorsport co. who also happen to be involved with Nobles.
