Hi Guys
Bit of advice please. Just went to open the boot and although it opens it doesnt 'rise up' like it is supposed to?
Still looks like its tight shut but will open so the latch / lock is ok. Its the standard spoiler so no weight issues and the hinge looks good as new. Really weighs a ton (almost too heavy for g/f to open) and as soon as you release it would slam shut if i let it.
Is there some sort of spring in the boot to hold it open, or has the hinge had it?
Any advice appreciated before i take the thing apart. It a Rev 3 by the way.
cheers Rob
[Mk2] [Generic] Boot wont stay open!!
Re: [Mk2] [Generic] Boot wont stay open!!
Highway Star
I just saw your post from Feb 10 re TCB Parts, if its a spring i need how easy are they to fit (i'm not a keen diy-ist).
Many thanks
Rob
Many thanks
Rob
Its dead easy Rob,mine had to be replaced,got one from here about £10-£15.
Paul
Paul
Rota torque drifts Japseed exhaust Apexi air filter Gizzmo ibc Apex springs Hks turbo timer 242bhp at .8 bar
cheers Paul
I'll try and get one at the weekend, just been out having a look at it. It looks in really good nick but the end of the spring seems to have 'broken free' from the hinge. Looks like it will come off quite easily.
I'll let you know when i get one. cheers
Rob
ps cant believe the weight of of the boot
Rob
If u need a hand with it gimme a shout
thanks very much may well do
All fitted Paul, i got a refurbed unit from TCB Parts
Good stuff,its a pain when you keep smacking your bonce on it
