the triangle shaped weight on the rear cross member? what does it do
as i need to remove it as it pushes the exhaust
[Mk2] [Turbo] rear cross member weight
Re: [Mk2] [Turbo] rear cross member weight
I believe it reduces vibration. Took them off before though with no detriment.
That rubber triangle heavy cheese wedge type thing? Mine was removed.
It's a harmonic damper, designed to help absord vibrations...basically a heavy weight right where you don't want it on the car...belongs in the bin
Doesn't weigh anything when it's in the bin
