I have recently been getting a knocking creaking noise from the front of the car,usually when i turn,but it is intermitant,some days nothing other days all the time.I have recently had my anti roll bars changed for new ones,thought it had solved the problem,but the noise is back.
ANY IDEAS
[Mk2] [SC] uk spec 1995 n reg non turbo
Re: [Mk2] [SC] uk spec 1995 n reg non turbo
when you turn ? Droplinks. Easy to change and cheap.
or tie rod or track rod end
Slarty wrote:
it's just that we subscrible to the theory of hitting it harder until it works. Or something falls off, in which case you've hit it too hard.
could it be the suspension mount,just guessing at the moment,its just annoying that it doesn`t happen all the time,no noise at all yesterday when going to work.As i had the drivers side done about 1 year ago.
