Another job I want to get finished now is to get my MS2 working
Any help with that much appreciated
Peter
Megasquirt ECU
Re: Megasquirt ECU
what help are you looking for ?
let me know, I have assembled and tuned a couple of them.
Re: Megasquirt ECU
elbon50 wrote:Another job I want to get finished now is to get my MS2 working
Peter
More infomation is required, not everyone would have read your other thread, you need to add to them in order to keep the infomation flowing. if you cant find it, i'll have a look and 'bump' it to the top
Re: Megasquirt ECU
Previous thread re Megasquirt is called "ECU Differences"
Have bumped it up to the top now
Thanks for the Club 4AG link Totacrolla. Havn't seen that before
Peter
Peter
Re: Megasquirt ECU
Does anyone know how I can find out the fuel flow rate through the injectors of my N/A Mk1b iin cc/min or lbs/hr please
Peter
Peter
Re: Megasquirt ECU
gon wrote:what help are you looking for ?
Thanks Gon. OK background. I have the MS2 which Greg Lebon built into an MR2 ECU case
Had it on my car a couple of months ago. Engine started & idled but hesitated on acceleration
Made some changes to the tuning which ended with engine not running at all. Made the silly mistake of not saving the original tune as an .msq
Been busy with other things recently. Original ECU is on at the mo. Car runs as normal with that. Really good to drive on road but hopelessly uncompetitive in sprints
Hoping to have another try with the MS2 very soon. Need figures for engine constants for my 1b and an .msq to start me off
If you can help I would be very grateful
Peter
Re: Megasquirt ECU
what is the engine ? is it standard ? Did you turbo it ? supercharged it ? changed camshafts ?
Re: Megasquirt ECU
Standard Blacktop, no turbo, no S/C, no special cams
Peter
Peter
Re: Megasquirt ECU
why don't u use the standard black top ecu then ?
toyota did a very good work on 4age ecu´s ... I firmly believe that if your engine is standard the best ecu for it is the standard one .....
anyway , I don't have maps for the black top , but I can give you some msq for the 16V with 288cams and ITB´s which are probably not that far off.
Re: Megasquirt ECU
Am currently using the standard Blacktop ECU
Want to try to improve performance using the MS2
Am interested in using high performance cams, etc
Have modified ignition setup to fit later
Would very much like to have the msqs that you mention
Peter
Peter
Re: Megasquirt ECU
Received your email. Thanks Gon
Will let you know how I get on
Peter
Peter
