[Mk2] [Turbo] Engine Decision
TRINDA1664
Post by TRINDA1664 »
Hello Guys
I am after a bit of advise....
I currently have a rev 2 turbo and I am looking to the future and replacing the engine.
The two options I am looking at are
1. Buying another rev2 engine and rebuilding it i.e balancing everything, forge pistons, hybrid turbo.
2. Buying a Rev 3 engine and doing a rev 3 conversion and doing the same mods.
However by looking in to it a bit a standard rev 3 engine is much more expensive than a rev2. Is the rev 3 engine that much better or would a clean rev 2 engine be as good?
Dan
cvega666
Re: [Mk2] [Turbo] Engine Decision
Post by cvega666 »
i'd stay with rev2. Build a forged one if you need more power.
Rev3 engine will cost more, and you have to account for wiring, ecu, and all work involved there...
ashley
Post by ashley »
If you're changing the engine anyway I'd go rev3+ O:)
irish_dan
Post by irish_dan »
5S ?
ashman wrote:If you're changing the engine anyway I'd go rev3+ O:)
^this :thumleft:
ToyotaTosh
Post by ToyotaTosh »
Rev 3!!! Steel headgasket for a start and apparently more reliable
TRINDA1664
Thanks guys for your replies! I am
Looking like I will do a rev 3 conversion.
Can any one give me some hints or tips on doing this conversion?
Is it right to say I need a complete rev 3, rev 3 ecu and engine loom?
