[Mk2] [NA] change steering wheel mr2 rev 4
walder
Post by walder »
i bought a rf snap off hub and new sparco steering wheel how do i fit thiss or do i need any fing else ?
lemonyfresh
Re: [Mk2] [NA] change steering wheel mr2 rev 4
Post by lemonyfresh »
Hi Matey,
Let me know if you have the airbag fitted (as you may remember i needed an airbag wheel!).
If you are going to be keeping the wheel incase of future sale not to worry, but if you are going to be parting with it I MIGHT be interested :thumleft:
I'm in two minds wether to buy an aftermarket wheel, or revert back to standard again. #-o
blacker than the blackest black, TIMES INFINITY!
JayUK91
Post by JayUK91 »
You'll need a suitable Rev3+ steering wheel boss on to which the snap-off hub can be attached. I'd recommend Momo bosses.
It's then a case of removing the small panels you see on the sides of the standard steering wheel and removing any screws you see. This will then free the airbag, and you can then access the central nut to remove the actual wheel.
I just fitted my new Sparco wheel to my Rev4 a couple of weeks back, massive improvement! :thumleft:
walder
steering wheel
Post by walder »
cheers nice wheel not sure about the shorts :thumleft:
lemonyfresh
Just popped you a text as my private messaging on here is going mad for some reason - my number sould be shown as it not set as private or anything :thumleft:
nickg07
Post by nickg07 »
What do you use to remove the big nut holding the steering wheel.in place?
