[Mk2] [SC] kenwood speakers
Please can you tell me if i can do a straight swap for the standard speakers,to kenwoods,without any hole problems or size problems.If so which kenwoods will fit in nicely.
Re: [Mk2] [SC] kenwood speakers
Why specifically Kenwood? If you have even the most basic fabrication skills, its easy to knock up a set of MDF adapters, or you can buy plastic ones from eBay for a tenner which will let you fit a much wider variety of speakers.
kenwood speakers
I just want kenwood,rather than another make,as my head unit is kenwood.Please if anyone can help,this would be great,maybe start with the rear speakers.My head unit is a kdc-bt50u it has 4 * 50 watt output with a built in amp.
