Server Disk Failed : Site Slow/ phpBB Critical Errors - 3,4 July
What's happening at the Club. You can post your suggestions and ideas here, along with reports of any problems using the site.
BenF
Premium Member
Post by BenF »
Folks,
We've lost one of the two disks that the IMOC server runs from, and until we get that swapped out ( I'm expecting Monday 4th, or Tuesday at the latest ) you may find the site at times running very slowly, or even not responding and giving errors such as :
Code: Select all
phpBB : Critical Error
Could not connect to the database
More news as we get it ...
BenF
Premium Member
Re: Server Disk Failed : Site Slow/ phpBB Critical Errors - 3,4 July
Post by BenF »
More site downtime this morning was related to this failure.
We're talking to our hosting providers and looking to swap the disk some time today, which will mean the server will be unreachable for upto 30 minutes, and then slower than normal for the following 4-6 hours as the RAID array rebuilds.
BenF
Premium Member
Post by BenF »
OK, new disk went in at 1pm and the RAID array rebuild has been happening since.
If you see any issues later today, post here.
Ben
pistol pete
Post by pistol pete »
i have no idea what any of what you said..
but thanks for ya hard work :thumleft:
BenF
Premium Member
Post by BenF »
:D
Think of it as equivalent of having to change the head gasket on one bank of a V6 ;)
pistol pete
BenF wrote::D
ahh now i am with ya :thumleft:
Slarty
Post by Slarty »
Guessing that there are still some issues? Had a page generation time of 81 seconds, and then another of 3-4 seconds....
BenF
Premium Member
Post by BenF »
Server is back to normal now, so 81 seconds is excessive. Normally, I find pages take under 1 second to generate ( eg this one took 0.14s ) and most pages should be under 2-3 seconds apart from peak times ( Lunchtime, early evening ).
If you're regularly seeing load times of more than 10 seconds, can you note the URL, time/date and post it up here so I can take a look?
What were you doing when you had this long page time - would you happen to be looking at one of the long discussion threads in OT by any chance?
Slarty
Post by Slarty »
Just happened again, loading the site up from fresh (from a bookmark)
http://www.imoc.co.uk/forums/index.php? ... 39ebce74c4
Only had Amazon running in an extra tab. The page took 77 seconds to generate.
Return to “Club News and Announcements”
