mr2 turbo US
shurik-n
mr2 turbo US
Post by shurik-n »
Hi guys
my name is Xavier, i'am french (thank's google) and i live Saintes (17 charentes maritimes almost La Rochelle for connoisseurs)
I have a MR2 turbo US rev 1. It's the only model with turbo and LHD)
I have (or rather a friend) many modif.
The 3sgte gen 2 was remplaced by 3sgte gen3, sway bar, hub, bushes and brake come from a rev2.
-gasket hks 1,2 mm
-cylinder head bolts ARP
-rod bolts ARP
-rod eagle
-forged piston cp 86
-crankshaft and connecting rod bearing ACL
-injectors SARD 800cc
-clutch exedy stage 2
-down pipe berk technology
-exhaust mongoose
-Apexi power fc + comander+ boost controler
-oil pressure and oil temperature guauge
-gearbox gen3 avec lsd
-rims rota torque en 7x17 with tire toyo T1R (almost dead^^)
-blow off dump valve Blitz
-damper koni
-braking rev2 with disc front and pads front and rear ebc yellow stuff, rear disc oem
-turbo timer blitz
-front spoiler rev2
-corner rev3
-rear light rev3
-home made ic with 76 piping alu,water cooler alu
I have lot of option. cruise control, air conditioning....
(I can not post photo!!!!)
Quigonjay
Re: mr2 turbo US
Post by Quigonjay »
welcome to imoc
you need 15 posts before you post pics
shurik-n
Re: mr2 turbo US
Post by shurik-n »
ok, thank you for the info
I post pictures of my engine and also that of my dyno test.
Re: mr2 turbo US
Welcome :thumleft:
Marky S
Re: mr2 turbo US
Post by Marky S »
Nice list there.. Looking forward to the pics!
toddjnr
Re: mr2 turbo US
Post by toddjnr »
bonjour. :D
shurik-n
Re: mr2 turbo US
Post by shurik-n »
lol merci :) or thank's
