On the way to work today, started getting a horrid grinding metal on metal sound!
I was pretty convinced it had to be the brake caliper being stuck on the disc, but the places I dropped it off to get the rear tires changed said the front wheels were turning freely and looked ok to them!
But it can't be ok, they said they haven't got time to have a look at it properly and will need to book it in again another time.
Problem is, I need the car tomorrow to get to one of these team building exercises in the middle of dartmoor!
Typical timing, was really looking forward to the nice drive across dartmoor, now it looks like I wont even make it!
Is there anything I can do at home to try and solve the problem? If the wheels are indeed turning freely, what else can I do?
This could be linked to other problems I have had with steering wheel shaking when I get to about 60 miles an hour.
I know the brake discs are warped at the front so possibly the brake calpiper has got stuck on, but if they said its spinning freely, it cant be this?
The steering wheel has always shook under heavy braking as expected by warped discs.
But the shaking all the time started after they took the wheels off, then they said it needed spiggot rings, which has helped a bit.
Now they have re-balanced the front wheels so that may help with the shaking.
Its the horrid metal on metal grinding sound which concerns me most since I really dont want to drive it when its doing that!
I know the brake shrouds behind the discs have completley rusted away, and I have pulled most of these off now in case they were getting caught up, which they did sometimes on full lock.
Cheers.
