Hi all where can i get some tein drop links from for my superstreets? Or it it a case of buying standard ones and heating them up and rotating then?
Tein superstreet drop links
Re: Tein superstreet drop links
coilover one is shorter,
(front)
you can get tein one
(cost
or
you can get customone
(or make it yourself)
also look at for sell section
and i think there is doc
in knowlegebase about using mini one
(shorter)
Ps: http://www.imoc.co.uk/forums/kb.php?mode=article&k=85
last part
or
last part
Any idea how short the front needs to be ive found 190mm and 200mm ones which should fit a mr2 with superstreets!
Rears i jus use standard!
Don't use the Avensis ones
- reports that they can cause problems on full lock ![](./images/smilies/spacer.gif)
http://www.autojumbled.co.uk/?p=491
Yeah wont b using avensis ones! Lol!
umm ![](./images/smilies/spacer.gif)
i think the problem can
be incorrect height of the arb cause by shorter drop link
, but i doubt it will cause steering problem on full lock
if i remember correctly, the drop link is direct behind the coilover
(center)
and the only point that travel is where it meet the ARB,
(coilover side is fix)
so i doubt the full lock issue is to do will shorter drop link, more to do with offset of the wheel and width of the wheel to start with,
but if you go custom droplink then you can alway adjust
(cutting the rod) to suit
