![Embarassed :oops:](./images/smilies/icon_redface.gif)
hope this makes sense!
![blackeye :eye:](./images/smilies/icon_blackeye.gif)
Raf wrote:is it the centre bolt? there is a large washer/spacer that sits between the mount and the bolt.![]()
take it off and see if its there? compare with the other side though.
dazzz wrote:You have a cup which sits under the topmount.
The top of the damper is slotted so will locate into the slotted hole on the cup.Yours isn't sat in the slot.
If you keep turning it, it may damage the cup so will never sit right again and knock.
Take off the whole leg, compress the spring then take the lot apart.You'll see it straight away.
You may need a new cup.
Not a big job really.
