What are the best manufacturers to buy from?
PW@Woodsport wrote:Be aware that 95% of the flywheels that are for sale in the US are for the 200mm Mk1a clutch type, so if you have a Mk1b the clutch won't fit.
aw11rally wrote:PW@Woodsport wrote:Be aware that 95% of the flywheels that are for sale in the US are for the 200mm Mk1a clutch type, so if you have a Mk1b the clutch won't fit.
And from experience a decent 200mm friction plate isn't particularly easy to get hold of.Helix quoted me over a week as they had to build one fitst.
Not many places hold high performance mk1a
(200mm) plates in stock.
SuperRedMR2 wrote:Yeah thanks for the reminder Paul, a few US companies I have contacted don't actually list the mk1b flywheel, they are usually Mk1a 200mm size![]()
I could however just get a mk1a clutch, as my clutch would probably have to be replaced anyway at the same time.
jnoiles wrote:
I have a brand new standard road clutch for a mk1a(200mm) sitting on the shelf you can have for free if you come collect.
PM me if you're interested.
It doesn't fit mine and it's been sitting on the shelf doing nothing for a year now.
monkeymax wrote:I'd be interested in one if you do a group buy too.Been meaning to get one for a while; now is as good a time as any if it's doable.
I can't imagine weight of the items will help much though.
cartledge_uk wrote:monkeymax wrote:I'd be interested in one if you do a group buy too.Been meaning to get one for a while; now is as good a time as any if it's doable.
Luckily, when it gets to a certain weight you can stick it on a pallet with no weight limit(I think)
Ebay also has some flywheel/clutch combo's.
But dont forget to add in taxes when they hit the uk.
