There for my track car build, I dont have an ic fan as i have a cc
I was wondering can i use the ic conector
or is there any benifit from refitting the ic fan
anyway any thoughts tips or advice would be welcome
thanks ken.
RyanRs wrote:Ah, apologies! i knew there was more to it than just that..
Unplug the black fan controller
(next to the ecu).
Job done
thats all i did with mine!
(iirc
-it was ages ago)
T.F.S. wrote:apart from the fans being on at speed and actually reducing airflow..
Ren0W wrote:It's best to have them on a switch.And used when slow city traffic, traffic lights, traffic jam.
etc etc.
T.F.S. wrote:lol, becuase the flow of the fans is FAR less than the natural flow at 80mph(or even 40mph)
to have them on at driving speeds is retarded, it reduces flow
pnicho wrote:You're automatically assuming that people will be driving faster than 70mph with the fans- what about if they're doing a sprint or hill climb, the amount of times that they will be above 70 will be less than the time they are below it.
This means that they will build up heat when they are going slow and under the most load
(acceleration) and then when they do need power because of the heatsoak etc they will have less.
We all know a colder charge is a denser charge.
I think you've gone off track here- the guy was asking about how to wire in his fans, he's bought them so therefor one would suspect that he wants to use them.
Same as I have a set that I want to use.
Why not create a post discussing this rather than hijacking the original thread?
Anyway back to point.
Kennym- you can do what toxo said or get a fan controller.
Personally I would get a resistor that's the same impedance as the fan and then run the positive from that to trigger a relay that will then turn the fans on.
I currently have a switch which makes the engine bay temp sensor go open circuit when I want them running.
It's not hard to do.
