For some reason it appears to be losing power and hesitating sometimes, seems familiar and I think its ignition related, you agree? So was gonna do plugs first, then probably leads since easiest to change, then rotar arms, dizzy cap, sound good?
I cant remember what spark plugs are best for stock tubbys? Been a while, is it the cold grade ones? But since I am running standard boost just normal ones would be fine?
Cheers.
[Mk2] [Turbo] For some reason it appears to be losing power and hesitating sometimes, seems fa
Rev3 TURBO TBAR running aprox 280bhp @ 1bar (320bhp after re-map soon...)
Re: [Mk2] [Turbo] For some reason it appears to be losing power and hesitating sometimes, seems fa
Also check the coil, they rust and split then water gets in and you have a misfire
Yeah will do. Thanks.
YEah could be any of them... Just got to slowly change each part one at a time till it goes away...
