I think I have a dodgy cold start sensor, as it is always lumpy when starting up from cold. 2 mins later it's fine.
Problem is on the EPC (which I don't have) they list about 3 temp sensors, which one is it?
Has anyone else had this prob and how did they find which one was the right one?
Cheers!
Edit- b**ger should be in electrical, can the mods move it ta!
Temp sensor
Re: Temp sensor
Can't help if you don't post some details as to which car you have
Re: Temp sensor
doh, sorry.
Got a Rev2 turbo. I believe there are 3 all together towards the front end of the engine block, but at £35 a piece I'm a little loathed to replace the lot like the dealership guy suggested!!
Re: Temp sensor
Water temp. sensor for EFI = 89422-20010
Re: Temp sensor
Thanks for that!
