[Mk2] [Turbo] inlet manifold weld?
hi can any tell me if the standard rev 1 inlet manifold can be cut turned around and rewelded for a boot mount? heard that its cast alloy and cant be welded dont know myself or will it have 2 be an aftermarket 1?
Re: [Mk2] [Turbo] inlet manifold weld?
I have seen them welded before, I would put a bigger plenum on the runners if your going to be cutting and welding, and your better off going side feed if your going to do that.
I keep considering hacking up my rmr to change to side feed as I run boot mount at the moment with rear entry throttle like your planning.![](./images/smilies/spacer.gif)
Graeme
Graeme
Re: weld
calum4492 wrote:plenum? iv heard ppl sayin that word but dont know what it is
The big bit that the runners go into, stock one has got a sticker on the top.
Give 3S a message I know James has made couple or more cutom inlet manifolds, he might be able to offer some help
