dai21t wrote:It'll sound xxxx though.Better off getting a proper de-cat pipe.
He said that if i gutt the cat i may loose power in the low rev range
Paul Woods wrote:He said that if i gutt the cat i may loose power in the low rev rangehe may well be referring to the back pressure loss which could reduce bottom end torque very slightly(if at all) but i doubt you'd feel the difference.
.the advantage of having the exhaust gas exiting faster and spooling the turbo up quicker way outweigh any negatives you might get due to reducing back pressure.
Took me 3 hours,a huge drill bit,12" socket extension,big hammer,chisel,you name it..
.horrible job.
.you will probably end up killing the cat temp probe too,doesnt matter though,just unplug it.
whoever said a gutted cat will sound crap should think before typing.
Fizzy wrote:leave it as it is! You wont notice the power improvment and the torque will fall through the floor..
